- Aug 14, 2006
- 54
- 0
- 0
Hello worthy techies!
I am hopeful you might be able to shed some light on an issue I am having.
My wife's computer died a few days ago. We were sitting on the couch watching Chuck when it suddenly turned off, flashing an orange light on the tower's power button. It is normally green when powered on and goes dark when you turn it off. The only way we found to get it to stop blinking orange was to hold the power button down for several seconds.
I tried opening the case and made sure all the connections I could find were nice and tight. Put it back together and pressed the power button. Nothing but blinking orange.
Because this is a Dell machine (a Dimension 9100 to be exact) I tried consulting with them. They advised it was a power issue. So I ordered a 550W Rosewill power supply from Newegg.com, sadly this did nothing. I think thought perhaps the motherboard battery had died, so I replaced that. No luck.
I am out of ideas. What could cause this? When you press that power button nothing happens, and I mean NOTHING. Fans dont start to turn, the drives dont attempt to spin... nothing. The only thought I have is that the mobo may have crapped out. Since the power button is wired to the motherboad and then the mobo is connected to the PSU, I suppose if there was a short somewhere it could cause this. Maybe?
Anyway, I would appreciate any thoughts or advice you have to offer.
Thanks!
Thanks!
