DEAD! TYLT Vu wireless Qi charger $39 shipped DailySteals.com
Status
Not open for further replies.
Roland00Address
2,196
260
I don't get it, what is special about this qi charger vs all the other qi chargers? It acts as a stand as well? Anything else? I ask for you can find many qi chargers for less than $40.
ControlD
5,440
44
From my limited research into Qi charging (until I realized my phone doesn't support it) the Tylt Vu gets high marks because it tends to work better than a lot of the cheaper models. It seems to have far less alignment issues than most of the cheap chargers. Not sure if that justifies the extra $$ but that is generally why people like it.
Kaido
Feb 14, 2004
51,071
6,937
I have both a CHOE & a TYLT. My TYLT broke - no visible issues, and I couldn't get ahold of customer service at ALL. I also had difficulty positioning my Yipin iPhone Qi case to properly charge on it. So I personally don't have a very high opinion of TYLT because of my experience. I bought more CHOE Qi chargers for $23/pop & have been very happy with them:
http://www.amazon.com/UPGRADED-Wirel...dp/B00C40OG22/
The one thing I did like about the Vu is that it had an angled kickstand, which was nice for using on the computer desk because you could see your lockscreen notifications while it was charging. Although I could probably just get an angled 8.5x11" paper stand & some double-sided Velcro & do the same thing with my CHOE, or build something out of wood or whatever.
RossMAN
Grand Nagus
Feb 24, 2000
78,963
412
Thanks for the CHOE recommendation. I'll be using it for work in a quiet office. Is there any way to disable the beeping without cracking open the case?
Have you heard of the Aukey Luna?
Kaido
Feb 14, 2004
51,071
6,937
Beeping? None of mine beep (noise-wise).
Edit: Haven't heard of that, looks neat tho!
mrdeucie
31
I have both the Tylt and two Anker chargers and I think I bought the Tylt one because reviews of it indicated it would also work with my old Nexus 4 along with my Nexus 5.
I think both chargers will work with both Nexus devices, so I can't really recommend the Tylt one unless you prefer it from an aesthetics point of view.
I actually prefer the flat Anker chargers as I have an app that keeps my phone on if it is tilted more than a certain degree, so if I used the Tylt one my screen would never shut off.
Dec 30, 2004
12,553
Status
