DEAD: Seasonic X750 Gold 3rd generation- $89.99 AR - AC - FS - Newegg
Discussion in 'Hot Deals with Free Stuff/Contests' started by Engineer, Dec 31, 2012.
  1. RaistlinZ
    RaistlinZ Diamond Member
    Oct 15, 2001
    7,633
    7
    Screw it. I bought one. :D I an always sell it and recoup my money if I find I don't need it.
  2. Engineer
    Engineer Elite Member
    37,925
    16
    Dead, thank God!
    I managed to not order this (well, not true totally. I ordered 2 times and cancelled both times)! :biggrin:
  3. country2
    country2 Senior member
    May 1, 2001
    525
    Which barcode is everyone using for rebate? Notice the large one on the Seasonic shipping box has same numbers as the small one on the product box.
  4. RaistlinZ
    Oct 15, 2001
    7,633
    7
    I was wondering this as well. Although my large lable on the brown shipping box I believe is just the tracking bar code, not the product bar code. The number on the product box bar code is different.
    Should I use this:
    [​IMG]
    or this:
    [​IMG]
  5. philipma1957
    philipma1957 Golden Member
    Jan 8, 2012
    1,712
    my guess is the brown box the bottom right one not the serial number. I need to send this myself. I may photo everything just in case.
  6. country2
    May 1, 2001
    525
    Those aren't same as mine. Mine on the shipping box has a label with x series in gold with the model number and a barcode with same numbers as whats on the barcode on the item box.
    Ok first pic is on side of shipping box and second pic is on the item box.
    [​IMG]
    [​IMG]
    #31 country2, Jan 12, 2013
  7. RaistlinZ
    Oct 15, 2001
    7,633
    7
    Hm, mine didn't come with that top pic like yours. Not sure what to do.
  8. country2
    May 1, 2001
    525
    You just need to use the barcode from the ps box.
    My box it came shipped in is a seasonic box. I guess yours is a generec box from newegg?
  9. ElFenix
    ElFenix Super Moderator and Elite Member
    Mar 20, 2000
    96,493
    314
    those are both the same. with the dashes around it, it seems like the one on the shipping box is meant to be cut you. though usually you'd use the lower UPC.
    for the above poster - you don't use the shipping label barcode.
  10. country2
    May 1, 2001
    525
    I plan on using the one from the shipping box since it has the same bar-code number. At least this way no issue with warranty/30 day RMA.
