Dead PC - bios battery?
fleabus
15
Yesterday I turned on my PC. It didn't boot...didn't do anything. Turned it off and on again. Booted up ok. I left it alone. An hour later, I went back to it. The hard drive light was frozen on and the screen was black like the video signal had gone away. I turned it off and on again, but this time nothing happened. No fans or drives wizzing. I had an old power supply, so I replace the one in my PC with it. Now all the fans wizz and the hard drives spin up. PC is still dead though. No beeps, no video signal. I took out everything but the ram and video card. Still no beeps or video signal. I even ran it without the video card and got nothing.
PC contains
P3 500 slot 1 on a slocket
Abit BE6-II
Geforce DDR
Sb live platinum
2 hard drives (40gb maxtor and 120gb WD)
2 cd roms (one plextor burner, one pioneer dvd)
3com ethernet card
My best guess is when the power supply went, it took the motherboard with it. I was wondering though if any of this could be cause by a dead bios battery. The board is only 2.5 years old, so I doubt that.
I left for memorial day weekend and my pc was off the whole time, but it was like this when i returned. I know the power flickered off and on while I was gone (alarm clocks were reset), but the pc is on a battery backup/surge protector.
Also, I had had problems with the power suppy fan in the past. It the fan was noisy, but still seemed to work ok.
TIA.
Ash2Dust
16
Sounds like the PSU took the MB out. Is your replacement PSU a known good, has enough wattage? It may have issues also.
Also, I've known people who have had a neighborhood power problem getting PGE (power company) to pay for their damaged tv's and computers.
Have you tried resetting the MB bios with a jumper (check ur manual for instructions)? This has helped with a failure to post bios once.
Go ahead and pull the video card too. In fact make sure you pull *all* cards, *all* hard drives (I had a HDD failure feign machine death), CD-roms, and floppy drives. All a MB needs to boot is a CPU and 1 stick of memory (or the minimum required sticks). The machine should make beeping noises if it can post, telling you that you're missing a video card. If it still doesnt make beeping signs of life, then 1 of the 4 is bad; PSU, MB, CPU or RAM. Swap each out 1 at a time if possible.
My last experience with a failed bios battery (486-100) is that you lose your bios settings (date, time, hdd info, etc) but it will still boot to bios screen.
japetto
94
I think that is probably the best guess. I would still remove pci/agp and ide/scsi components and try to get it to POST. Remember that you can only hear error beeps if you system speaker is good-to-go.So I would check that too!Good Luck;)
