Dead Mobo -- replacement with 680i or 750i?
  • Thread starter Deleted member 4644
  • Start date
D
Deleted member 4644
I have an SLI set up with two 8800GTs and an intel cpu. It was on an EVGA 680i that is dead and doesnt havent warranty :(
Should I replace it with anohter 680i or with a newer 750i?
TC91
1,164
750i if you want support for the 45nm quads. it might be cheaper than the 680i too. but if dont plan on getting a 45nm quad you might as well get the cheaper motherboard that you can find.
