I've had a P4 1.6a and an Asus P4S333 for a little over a year now. I took the combo out of my case, and put them in a new case, because I am selling it to a friend. It was posting fine, and I was in the middle of trying to install windows on a fresh HD. The windows install wouldn't complete...it kept getting hung up after it copied files and said to restart. Anyway, after a few reboots and reformats with MaxBlast software, the computer stopped turning on.
The green LED lights up on the mobo, you hit the power and it turns on for about half a second. (I can tell by my LED Case fan) Then nothing...if I hit power again nothing happens, not even the case fan light blink on. If I remove the power cord long enough for the standby LED on the motherboard to extinguish and plug in the power again, then I get the same half second of power where the case fan lights up. I tried another power supply with the same result, so I think I can rule that out.
So how do I determine if it is the motherboard or the CPU? And could this have been causing the problem I had the previous two hours when I couldn't get the windows install to complete?
I tried to remove the mobo from the case and run it sitting on an antistatic bag on top a box, but the same result.
I found this info, which seems to be related to my problem:
"Dead System (no POST, screen blank, no beep)
The most likely cause is a device that is shorting out the power supply. An improperly inserted memory module, a defective adapter or device can cause a short circuit. To prevent damage to a power supply, the system board must present a "POWER GOOD" signal to the power supply in 150mS or less. If this does not occur, then the power supply shuts down internally"
now how i do find the short?
THanks
THanks
