[DEAD]JVC GR-D850 MiniDV Camcorder with 35x Optical Zoom Refurbished
Pardus
Price: $129.99. $5 to ship. 90-day warranty.
Features:
* Powerful 35x optical zoom, The image is magnified optically to eliminate jagged edges. Images can be further enlarged up to 800x when combined with the digital zoom
* 115 minute data battery, slim and powerful long life data battery allows you to shoot with peace of mind
* DATA button reports the remaining battery and recording time can be easily viewed, even when the power is turned off
* 3D NR automatically provides a more accurate noise reduction; video noise is reduced by 30% in low light for a 2dB improvement in the signal-to-noise ratio
* JVC digital video cameras are equipped with 2.7 inch 16:9 LCD monitors. Our wide mode will maintain a high picture quality, plus give you a more realistic visual due to the extended field of vision
* Clear LCD feature reduces reflections and glare to maintain a clear, visible and bright viewing during outside recording
* Super High-Band Processor
* Web-Camera Function via IEEE 1394
* NightAlive, Boosts light sensitivity for a bright picture even in environments with minimal illumination
* Digital Effects and Scene Transitions
* Conveniently, access a multitude of functions with the 4-way one-finger control on the LCD door. Simply press the four ?compass points? on the circular control to navigate menu items and manual feature settings during recording and playback
Specifications:
* CCD: 1/6? 680k
* Optical Zoom Ratio: 35:1
* Digital Zoom Ratio: 800:1
* Maximum Digital Still Size: 680×340
* Clear LCD Monitor: 2.7? Wide
* 16:9 Wide Screen Mode
* Stick Control
* Data Button/Auto Button
* Auto Illumination Light
* NightAlive
* Power-Linked Operation
* Data Battery: BN-VF808
* Multi-Language On-Screen: 7 Languages (Eng. / Spa. / Fre. / Kor. / Jap. / Por. / Chi. [Traditional])
* DV Input/Output
* Format: DV (SD specifications)
* Power Source: (Batt) 7.2 V / (AC adapter) 11 V (using LCD Monitor)
* Power Consumption Using LCD: 2.6 W
* Cassette: Mini DV type
* Lens: F 2.0-4.1, f=2.3-69 mm
* Filter Diameter: 27mm
* Dimensions WxHxD (Including parts protruding): 2-13/16? x 3-1/16? x 4-5/8? (71×77 x 117 mm)
* Weight (Without battery): 0.93 lbs.(420 g)
In the box:
* JVC GR-D850 MiniDV Camcorder
* AC Adapter
* Battery Pack
* Shoulder Strap
* Audio Video Cable
* Lens Cap
* Users Manual
