[DEAD] HOT: PartsExpress 6' Optical Cable - $3.25 shipped! 12' Optical Cable - $4.50 shipped!
Yzzim
11,990
FREE SHIPPING IS DEAD
PartsExpress is having some awesome deals on Optical and standard RCA cables. To make it even hotter they are offering free shipping!. In order to find free shipping you'll have to search for it.
Part 180-940 - 3' Toslink optical cable, $2.80 each
Part 180-942 - 6' TosLink optical cable, $3.25 each
Part 180-944 - 12' TosLink optical cable, $4.50 each
Part 180-128 - 6' Gold Molded S-Video Cable, $2.40 each
Part 180-129 - 12' Gold Molded S-Video Cable, $2.95 each
Part 180-132 - 50' Gold Molded S-Video Cable, $6.50 each
Part 180-120 - 3' Gold Plated A/V Cables (3 RCA cables mated), $2.80 each
Part 180-118 - 6' Gold Plated A/V Cables (3 RCA cables mated), $3.25 each
Part 180-121 - 12' Gold Plated A/V Cables (3 RCA cables mated), $4.95 each
Part 180-124 - 20' Gold Plated A/V Cables (3 RCA cables mated), $8.55 each
LEDs Galore! - Starting at $.12 each
Buy.com deal is DEAD, price is up to $7.99
I got sick of seeing a 3' optical cable at Radio Shack for $20 so I decided to look online.
Cheapest I could find is a 6' Gamester PS2 Optical Cable at buy.com. I hooked it up today to my DVD player and stereo reciever and it works just as well as the $20 optical cable.
Buy.com shipped it via USPS Media Mail and I recieved it in 2 days from the time I purchased it. Very fast considering it was Media Mail and it was free.
BTW, the optical cable shipped from Memphis, TN.
If you want pictures just let me know.
Yzzim
11,990
Originally posted by: yumyum
Nice find. Optical is optical right?
correct :)
Just because it says PS2 optical cables doesn't mean it _only_ works on the PS2.
Like I said in my post, I hooked it up to my DVD player (RCA) and my Stereo Reciever (Sharp).
I don't even own a PS2 :)
KCheng
80
What exactly is optical cable? What does it look like? What does it enhance?
Thanks!
Irascible
118
Not all cables are the same. There are different connectors, though that shouldn't be an issue here since we're strictly talking game consoles (I assume they all use the same connectors).
The other thing: The better ones have a spring loaded mechanism that holds the cable firmly in place indefinitely. The cheaper ones just snap into place. Theoretically the snap in style cables can eventually loosen and you start to get errors. Do we know if it's spring loaded or not?
Yzzim
11,990
Thanks!
I'm not an audio buff or anything, but here's what I know.
An optical cable is a cable that connects electronic components together. Only works to connect audio.
Looks like any other cable I guess. There's little plastic pieces to protect the ends of the cable. You need to take them off before you plug the cable in.
It enhances the sound. I believe it's one of the clearest and best ways to connect audio components.
Yzzim
11,990
They're definitely not spring loaded, though neither was the $20 cable at Radio Shack.
hclarkjr
i have a home theater system that has optical connections and there are no spring loading connections on it at all, just push the cable in. and yes it is for audio only, it is mainly for dolby digital 5.1 connections. the sound is far superior to hooking up via RCA cables.
chuenl
273
How do you know it's 6 feet ? I didn't see anything specifying if this is a PS2 cable and how long this cable is.
The only optical cable that says PS2 is $23.99 here.
Yzzim
11,990
Originally posted by: chuenl
How do you know it's 6 feet ? I didn't see anything specifying how long this cable is.
I already purchased the cable and have it in my hands.
I'm about 6' tall so I held the cable up and it's the same length I am.
I thought it was only going to be 3', but it was a pleasent suprise to see it's 6' :D
iluvdeal
1,975
Thanks!
In my case, I needed to connect my DVD player to my receiver so I could get the DD5.1/DTS output of movies. You only get stereo if you connect them with the RCA audio cables.
KCheng
80
Would this be applicable to the XBOX as well?
Actually, is it necessary or worth it?
Thanks guys!
hclarkjr
i have an XBOX and must say it is very much worth getting the advanced video pack for the xbox and hooking it up that way, most of the xbox games have dolby digital 5.1 built into them and it rocks to play a game in full dolby 5.1. it costs some $$ to do but it is worth it at least to me.
Yzzim
11,990
Thanks guys!
On the back of the box it says "Compatible with Xbox High Definition A/V too!" or something similar to that.
It's up to you on whether it's necessary or worth it. If you want the best sound coming out of your Xbox, then yes, it is necessary.
KCheng
80
hclarkjr:
So does this mean, solely the optical cable will not work? I'm not seeing how it would buy just buying the optical cable, becuase the Red, Yellow, and White all come into a plug that plugs into the XBOX.
Is the A/V Definition Pack the only way to go for Dolby Digital?
Thanks!
hclarkjr
yes, that is the only way you are going to hook up the optical cable, you will not need the RCA cables then, also on AV pack is connection for Svideo hookup for your TV which will give you better picture too provided your TV has Svideo input
MustISO
12
I'm in, I needed one for my PS2. I personally prefer the digital coax for DD/DTS sound but there's lots of DVD players which only have optical connectors. You'll hear people argue all day about which is better. Optical is more fragile and some tend to loosen over time. I doubt most people would be able to tell the difference in a blind test.
RedShirt
1,793
This is a HOT DEAL!!!! Even if you don't have a purpose for one, order one! You'll probably need one sooner or later and Yzzim is not lying, it's AT LEAST 20 bucks for the short crap in any store.
I'm getting 2 even though I have no need for any more currently, I know I may need them later.
wfay
912
i agree this is an excellent price for an optical cable
i got 2 or 3 of these PS2 optical cables from a video game retailer that had them on clearance for about this same price. they have been working GREAT between my computer, receiver, and minidisc recorder/player.
the ends on these cheaper cables are all plastic and somewhat flimsy but hey they work!
OulOat
5,769
Yeah Yzzim, can you put up a few pics. If it's possible put up some good pics of the ends. Thanks.
RedlineSys
150
Thanks guys!
Hmmmm, for $4.99 I might have to give this a shot. Thanks.
