- Jun 15, 2000
- 30
- 0
- 0
You know what I dislike about the Addtronics case is the one hole for a 3.5" drive out. I just like being able to add a SCSI zip drive to my case with the floppy if the mood strikes me, without having to cludge some cutup fix.
I am also all about quiet this time around. I currently use the Enlight 7237 single panel version and it is one big echo chamber for my fans. I do not like the idea of using spray foam to ensure a quiet case and do not think 1" sheet foam on the inside will allow enough free airflow since it cuts down on the available space inside.
The AMK case I have zero experience with and know nothing other than a few favorable reviews. But it allows you to place another external 3.5 drive.
Any input in my ramble?
Here is a link to the Addtronics case specs:
http://www.addtronics.com/6896a.htm
~$80 US for the case from Addtronics (ahem jfh)
~$50 for an enemax 300watt PS bought separately
Here are specs of the possible AMK case I would buy before modifying it:
http://209.87.55.168/24_ocd.htm
OCD-0003 24" tower
300 watt removable side panels,
1 3" fan mounted internally (intake)
$99.99 Canadian
OCD-0003 24" tower
$99.99 Canadian
