Originally posted by: Elixer
Just remember, some people say that using a coupon will void the rebates. (Read your receipt, and see if it mentions something about this)
Also, I got this PVR-150, and was not impressed at all. Some reason all channels were in mono, and the picture wasn't that good compared to my old 878 card.
Maybe I just got a dud of a card, since I also had stuttering issues.
Other than this, it is a OK card for $~60 +TAX...
I'll try to answer some questions:
1) I haven't seen anything that mentions a coupon voiding the rebates in the forms.
2) I have the MCE version as well and that had a problem with stereo mode because of the drivers supplied with the CD. To fix it, I uninstalled the drivers and then installed a previous version which then allowed for stereo sound. Some of the newer drivers are having stereo problems so you may need to find one that works properly with your configuration. Not really a big deal but you can check out this site for more help:
SHSPVR
3)Video settings can be tweaked...check the shspvr site above. Also, I've found the Nvidia DVD decoder to work the best so far. And you can make adjustments to PQ etc with / enable hardware acceleration.
4)Should work fine with a DISH / cable box since it includes an IR Blaster that is supposed to control those devices...but YMMV.
5)I'm using a 2.0ghz Athlon XP with 512MB ram and haven't had any problems what so ever. CPU USAGE is around 30% watching TV / timeshifting and a few percent (i.e. 2-4) while recording / not watching TV. Watching while recording is still around 30%.
6) As far as I know NTSC only supports stereo. If you have Dolby Pro Logic enabled on your stereo then you'll get "simulated surround sound".
7) Coupon codes can be entered at step 3 of the checkout under Billing Information and where it says "Would you like to use an eGift card, gift card or merchandise card, or apply a coupon?" -- check the "Yes" option right above where you enter the credit card info.
Better hurry though since now it looks like they may not deliver anymore. My area only gives the pickup option. And last day for the deal is Saturday.
Also if you are looking for a decent front-end, take a look at GBPVR. It's free and similar to Media Center Edition (not quite as poslished though), but is the most customizable, fastest and stable front end that I've seen. And I've tried MCE, Meedio, Sage TV, BeyondTV, Media Portal etc:
GBPVR
