[DEAD]External USB 23-in-1 Memory Card Reader, Silver
Pardus
Your cost: $5.99. Free ship.
Specification
* This USB 2.0 memory card reader is the ideal companion for your digital media. Avoid the hassle of moving photos, music, data and more between multiple media platforms.
* Ideal for portable use - at home or on the road, desktop or laptop, your data will be ready.
* Features and Specifications:
o Hot-Swappable
o Plug and Play
o USB 2.0
o Ultra High Speed - Read: 4.3Mbps, Write: 1.3Mbps
o LED indicator lights
o Supports Windows XP, 2000, 98, and Mac OS 9.2 and higher
o Color: Silver
* Installation tip: The driver CD is only needed for Windows 98. Otherwise, just plug in the device and it will install automatically.
* Suggested Applications: Compact Flash CF I, CF II, CF Ultra II / MicroDrive / Smart Media Card / xD / Secure Digital: SD, SDHC, SD Ultra, miniSD (with adapter), microSD/TransFlash (with adapter) / Multimedia Card: MMC I, MMC II, RS-MMC, HS-MMC / Memory Stick: MS, MS Pro, MS Duo, MS Pro Duo, MS MG, MS MG Pro, MS MG Duo, MS MG Pro Duo
