Chaintech VNF3-250 Board
I have been using the onboard ethernet for about a year now and everything was working fine. Then, my DSL connection goes down for about an hour, now I cannot get it to work again. I have two computers hooked up to the same DSL connection through a router, and the other works, so I know the DSL connection is fine. Anyone have any ideas as to how to fix it, without having to reinstall windows? I have uninstalled and reinstalled the drivers for the LAN. I also have a old PCI ethernet card, which doesn't recognize the signal either. Both recognize something is set up, the port still lights up, and windows says it is enabled, but I just get 0 sent/0 received. If you need any more information, I will gladly provide it. I will try most anything.
Thanks.
Thanks.
