[Dead] CompUSA: 9/19-9/25: Netgear Wired and Wireless (802.11b, 802.11g, Super-G) Products - $9.99 to $79.99 AR
ActuaryTm
6,858
12
Wired:802.11b:802.11g:Super-G:Can provide a scan of the advertisement, if deemed necessary. Links to the rebate forms will be added when made available online.
Promotion begins September 19th.
BornStar
4,052
Wow, good stuff. I wish I were around a CompUSA since I've been looking for a WGR614 for a reasonable point. I don't need it for the speed, I just want the WPA.
ActuaryTm
6,858
12
Added links to all rebate forms. A number of differences existed between the weekly advertisement and the online cost, and are thus reflected above.
Johnbear007
4,570
Anyone have experience with the netgear USB wireless adapter? How does it compare to the syntax one from e-cost?
fallenangel99
1,721
If I get the WG511 54Mbps Wireless PC Card Ethernet Adapters, will it work with my Linksys BEFW11S4 802.11b??
and one dumb question (i think): whats the diff. btwn the wireless pci adapter (wg311) and wireless pc ethernet card (wg511)
Not sure what to get for my desktop
Thanks =)
ActuaryTm
6,858
12
It certainly should. However, be aware that the connection will only be viable at 802.11b rates.
The WG311T utilizes a PCI interface, while the WG511T uses a PCMCIA interface.
The WG311T would be the choice for a desktop. The WG511T would be better suited for a notebook, or a PCI card that accepts a wireless PCMCIA card (like this one).
Should also mention if one places most routers near a desktop, a wireless PCI is not required, as most wireless routers offer a built-in four port 10/100 switch. Of course, for desktops in alternate locations, a wireless PCI card would be a viable solution.
