Originally posted by: p0lar
Sweet!! Bold too...
I happen to have one of those as well, but not quite as strong.. I doubt it would pick up 30#, but I'm pretty sure it would do 20# - I've got a 25# barbell hanging out to test with as well.
I think the test logic may be somewhat skewed. The same test could be applied for vibration. I'll go drop a linksys router from 1 meter - the plastic may crack, but that is probably it. Now, if I drop it 5000 times, we will probably notice a considerable degredation of performance (or the absence of performance due to catastrophic failure). If you take the magnet and constantly whir it around the component or near the component so that the field strength (maybe) and polarity changes irregularly - I would hazard a piece of equipment that it may make a difference.
This tempts me to try it on this 1601....
I'll may set up this extra 1601 back to back with a 2507 that is hanging out and give it a whack while using it to pass packets to see what the effects are on performance over an extended period of time. I would also put it through a few reboots to make sure that the flash RAM and DRAM aren't affected as well. (=
I'll open up the case of my sub and literally place the 1601 underneath the speaker and leave it.. no harm, no foul - but if it blows.. oh well, we'll be one step closer to understanding the inherent effects of sub-woofer-induced equipmental homicide. (rofl)
This *could* be fun. And no, there's no way I'm going to let it near my PIX...
Anyone with any modifications to the experiment? Maybe I should paint stripes on the 1601 first?
