I've got a 2006 Toyota Yaris with about 70,000 miles.
Up to this point it has been acting completely fine. All electrical systems work wonderfully. Starts are nice and quick.
This morning I go back to the car and nothing works. Power door locks don't work. Interior lights don't work. The headlights and interior lights were all in the off position. No sounds come after turning the key.
I had someone jump me and the car started up with a slight hiccup.
I left the car idling for five minutes and noticed that the interior lights were flashing. If I press the gas the lights become constant.
I used a multimeter to check the battery at the terminals and the voltage fluctuated between 12.7V and 13.1V.
I went to go drive the car around after seven minutes of idling. Manual transmission. Put it into reverse. Reversed a bit. Then it just shut off completely when I went to put it into first with the clutch still pressed in.
Ummmm... I'm not sure what's going on here. I want to say that it's the alternator, because I don't think batteries fail so suddenly (overnight). There also might be corrosion around the battery terminals but again I don't know why that would contribute to such a sudden failure.
