(Dead) 15" Chrome TFT-LCD Monitor $199.99 AR & coupon At officeMax (in limited areas)
MysticMan1
2,711
(DEAD) Syslcd 15" Chrome TFT-LCD Monitor (#20196681) $399.99 - $80 instant rebate - $30 Mfg MIR - $40 OfficeMax MIR - $50 off $250 OfficeMax coupon = $199.99 At officeMax (in limited areas) or order by phone.
15" Monitor
* Active matrix TFT display
* 0.297 x 0.297 mm pixel pitch
* 1024 x 768 resolution
* 210 cd/m² brightness
* 350 : 1 contrast
* Internal speakers
* Wall mountable
Link to syslcd specs
Link to 15" Chrome TFT-LCD Monitor
Link to OfficeMax 15" Chrome TFT-LCD Monitor ad (Memphis, Tennessee) ( If you don't get the ad page click refresh.
Click here to see "this" week's OfficeMax ad for your area
OfficeMax has three different ads running in different cities at different times, they sometimes rotate the ads from city to city so the ad with the 15" Chrome TFT-LCD Monitor might be in your city next week or the weeks after that.
Or you can put in a phone order at (1-877-633-4236) tell the CS Rep the item number and the price, what city you saw the ad for the LCD Monitor in and you want to use a $50 off $250 OfficeMax coupon code.
For Officemax coupons do a search on Google.com key word "Officemax coupons".
Link to mfg $30 rebate
Link to officemax $40 rebate
LCDs. LCDs are transmissible displays, because they rely on a bright backlight, and the individual liquid crystal cells either block or transmit the light in order to create the viewable image. Generally, three liquid crystal cells are arranged next to each other to create a single pixel. The individual cells get their color from the light passing through red, green, or blue filters; almost all LCDs' filters are arranged in vertical stripes. LCDs fill the entire display area with an image, so the panel size is the same as the viewable-area size. This means that a 17-inch LCD will have about the same viewable area as most 19-inch CRTs, and a 15-inch LCD is equivalent to a 17-inch CRT.
LCDs are the standard for notebooks, because they are flat, lightweight, and require little power. These advantages in size and power make LCDs attractive for desktops as well. LCDs can be divided into two main categories:
Passive matrix. The liquid crystal cells are switched on and off at the edge of the panel by rows and columns. Often the panel is divided horizontally into two regions, creating what's known as a dual-scan display. Passive-matrix LCDs are less expensive than active-matrix LCDs, because they're much simpler to build and are rarely found in desktop LCDs. Instead, they are most often found in low-end, lesser-priced notebooks.
Active matrix. Also known as thin-film transistor (TFT) LCDs, because they have tiny transistors at every liquid crystal cell, Active-matrix transistors are used to turn the cell on or off. Because of the technology used, these panels are more expensive to make than passive-matrix LCDs. The upside is that the images are sharper, and the cells respond faster, making the displays suitable for moving images.
Coraanu
1,112
Sweet deal man!
Just clarifying on the pricing:
399.99 - 80 IR - 30 MMIR - 40 OM MIR - 50 off 250 coupon = 199.99
SemperFi
2,002
Coraanu
Thanks for clearing that up. I added it up three times and came up as $240. I would be all over this if I hadn't bought an Envision a couple of weeks ago. Nice deal.
I just checked my local flyer doesn't appear to be available in my area.
Semper Fi
Tallgeese
5,775
GREAT GOOGLY MOOGLY!!!
Lot of $$$ tied up in a rebate, but pretty awesome find, I must say.
AmishPcFreak
148
I must be a clueless igit, but I can't find the $50 off 250 coupon... anybody have a website location?
Gracias!
APC
Coraanu
1,112
Gracias!
APC
Try the famous or infamous thick wallet. =]
pokester
14
Or you can put in a phone order now ...
Looks attractive to me, but the $50 off $250 online (only) coupon expires on 8/31 while the $40 rebate is available only for purchases made beginning on 9/1. Maybe if I cross the international date line and place the order on 9/1 while it's still 8/31 in the US ...
EDIT: Per the posts below, I was wrong. There does indeed appear to be a $50 off $250 code valid thru 12/31/02. Thanks for correcting me.
Coraanu
1,112
Not true, there is a 50 off 250 that expires 12/31. Hit up the thick wallet.
bentwookie
1,771
keep looking, there is one good through 12/31/02
vladgur
1,825
R: 13ms F: 27ms
response time on these things is pretty low, plus its analog, but for $200 what the hell. Do you guys know if they have these on display at OM?
Anyone find any reviews?
CDD
16
Each of the rebates states that it requires a copy of the receipt and the original UPC code. Since officemax lists both rebates in their ad, I assume that it is OK to send a copy of the UPC to one of the rebates. Anybody know which one????? Gotta get some more of that double-rebate goodness after the $14.95 maxtor deal from last week...
Engineer
701
Looks like Instant rebate already on website...
Was $399 earlier...now $319.
Too bad the rebate doesn't work until 9/1! :(
Nice find....
mnaeem25
45
The only thing I found was 50 off 250 for online order only. I really appreciate if some one can PM me with the coupon code for 50 off 250.
Thanks in advance
MN
