I need some suggestions regarding the value of the Xmit Power in DDWRT. The default is 28Mw but I have put it on 50Mw to be able to connect users in the 2nd Flr. Is this good or bad for the router? WRT54GL v1.1 & WRT54G v2.2 with Linksys 7dbi High Gain Antenna.
Also, while browsing for the net for answer about the xmit power, I stambled on this topic about routers that has 2 antenna. It seems that the router is change its TX & RX from left or right depending on the signal thats its get?
http://www.linksysinfo.org/for...showthread.php?t=54299 (1 vs 2 Antenna)
This is where I want to ask about DDWRT Antenna Positioning. Which is better for TX & RX? TX = Right & RX = Left? or vice versa? or just keep it on Auto?
Currently it is on Auto but the users in the 2nd Flr says their signal is swinging up & down from time to time.
Just want to know the consensus. ^_^
