M menomena Junior Member Jul 31, 2007 17 0 0 Aug 12, 2007 #1 My RAM is only running at 166 MHz when it should run at 200Mhz. Why is this? I have an ASUS A8R-MVP motherboard running an FX-60. All the timings are the same and at stock. They should be running at stock voltage, as well
N Noema Platinum Member Feb 15, 2005 2,974 0 0 Aug 12, 2007 #2 Some older s939 mobos had some problems running DDR PC3200 @400MHz if 4 sticks of RAM were used, if memory serves me right.
T tw1164 Diamond Member Dec 8, 1999 3,995 0 76 Aug 13, 2007 #3 you should be able to manually set the SPD to 200
