- Nov 4, 2005
- 1,855
- 0
- 0
DDR2 800 (PC2 6400) PDC24G6400ELK 5-5-5-12 2.0V 240-Pin SDRAM $62AR / 4GB (2x2GB) kit, Newegg
http://www.newegg.com/Product/...x?Item=N82E16820220227
SEEMS HOT to me at approximately $32/2GB DIMM after rebate and $5.58 shipping costs
given that it is quality memory that's faster than one usually finds for this price level.
WARNING -- MULTIPLE PRODUCT REBATE -- the rebate is good on any ONE rebate over a list of like ten Partiot memory products. If you buy / rebate this one, you must NOT buy and of the other products in this offer period if you expect to get a rebate on this one.
MIR here:
http://images10.newegg.com/Upl...RSMar18Mar3108lt12.pdf
Patriot Extreme Performance 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
Patriot 4GB(2 x 2GB) 240-Pin DDR2 800 (PC2 6400) Dual Channel Kit Memory - Retail
Image Viewer
Original Price: $86.99
You Save: $10.00
$76.99
($56.99 after $20.00 Mail-In Rebate)
3 Business Day Shipping $5.58
(Not available in HI, AK and PR)
In Stock
Add item to Cart
Model
Brand Patriot
Series Extreme Performance
Model PDC24G6400ELK
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 4GB(2 x 2GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 5
Timing 5-5-5-12
Voltage 2.0V
Heat Spreader Yes
Features Bladed aluminum heat shields to improve module stability
RoHS Compliant
EPP Ready
Recommend Use High Performance or Gaming memory
MIR here:
Image Viewer
You Save: $10.00
$76.99
In Stock
Add item to Cart
Model
Brand Patriot
Model PDC24G6400ELK
Tech Spec
Cas Latency 5
Timing 5-5-5-12
Voltage 2.0V
Heat Spreader Yes
RoHS Compliant
EPP Ready
