DDR2-667Mhz showing as DDR2-333Mhz
jigneshd
Hi Friends,
I purchased a new PC with following Config.
Processor : Intel(R) Core(TM)2 CPU 6320 @ 1.86GHz
Memory : Transcend JetRam 2GB(2 Modules each of 1GB) DDR2-667Mhz.
Mother Board: DG965RY
On CMOS it shows as DDR2-667 Mhz. but when i run utilities like SiSoftware Sandra Lite XI.SP2, PCWizard 2007, cpu-z-140
Following is what i get. it show DDR2-333 Mhz. Have a got a wrong memory module or is it faulty ?
PLS Guide.
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 8GB
CHAN A DIMM 0 - J6H1 : Transcend Information 0x4A4D33383851363433412D36202020202020 0x00000000 Unknown DIMM Synchronous
DDR2-SDRAM 1GB/64 @ 667Mt/s
CHAN A DIMM 1 - J6H2 : Empty
CHAN B DIMM 0 - J6J1 : Transcend Information 0x4A4D33383851363433412D36202020202020 0x00000000 Unknown DIMM Synchronous
CHAN B DIMM 1 - J6J2 : Empty
Memory Module 1
Manufacturer : Transcend Information
Model : JM388Q643A-6
Type : 1GB DIMM DDR2-SDRAM
Technology : 16x(64Mx8)
Speed : PC2-5300U DDR2-333
Standard Timings : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Version : 1.2
Date of Manufacture : 25 December 1999
Memory DC Line : 1.8V
Set Timing @ 333MHz : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Set Timing @ 267MHz : 4.0-4-4-12 (tCL-tRCD-tRP-tRAS)
Set Timing @ 200MHz : 3.0-3-3-9 (tCL-tRCD-tRP-tRAS)
Memory Module 2
Version : 1.2
PC Wizard 2007 Version 1.73
Operating System: Windows Vista (TM) Ultimate Professional 6.00.6000
Report Date: Thursday 31 May 2007 at 09:56
> Physical Memory : 2048 MB DDR2-SDRAM
>> General Information
J6H1 (CHAN A DIMM 0 ) : 1024 MB - DIMM
J6J1 (CHAN B DIMM 0 ) : 1024 MB - DIMM
>> Information SPD EEPROM (J6H1)
Part Number : JM388Q643A-6
Serial Number : Unspecified
Type : DDR2-SDRAM PC2-5300 (333 MHz) Format : Regular UDIMM (133.35 x 3)
Size : 1024 MB (2 ranks, 4 banks)
Module Buffered : No
Module Registered : No
Module EPP : No
Width : 64-bit
Max. Burst Length : 0
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Manufacture : Week 0 of 2000
Supported Frequencies : 200 MHz, 266 MHz, 333 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 15 clocks @333 MHz
Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 20 clocks @333 MHz
>> Information SPD EEPROM (J6J1)
Module EPP : No
Width : 64-bit
Voltage : SSTL 1.8v
CPUZ
Does not show any deails except its say 2GB. Wonder Why he is not able to detect further details.
Regards
Jignesh.
jigneshd
Hi Striped,
1. Let me confirm you its DDR2-667 and not ddr-667.
2. If 667 represents speed 667Mhz can you explain how come 333 MHz is correct.
I don't understand also I don;t have any Manuals.
Regards
striped
10
Well, it doesn't matter. All Double Data Rate SDRAM including DDR, DDR2 and DDR3 double transfer rates. Thus a 333 MHz DDR2 chip has an effective clock rate of 2*333=667 MHz.
