DDR voltage and Vcore voltage
DisposableHero
546
ok my question has to do with these 2 voltages... first of all my 1.4 TB with 256 crucial ddr maxes seems to only be able to go to 145 before it will not boot.. i was told i could up the DDR voltage to maybe pass this 145 point.. but i did and it didnt seem to do anything different... do i have to up the Vcore voltage along with the DDR to improve stabability? im trying to run it at 10.5 x 145+ ... MBM 5 tells me my vcore is at 1.81 right now. what should i do.. i have an epox 8k7a
overdog
62
I'm no expert at overclocking, but for the sake of giving you an answer, yes, you need to increase your Vcore. You can also try lowering your multiplier. I had to increase my Vcore to 1.90V to get my 1.2 T-Bird to run at 1.4 (10x140). I didn't have to touch DDR though.
Renob
7,596
Im running my tbird at 1.9volts and my ram i turned up one notch on its volts It will help with stability problems.
