DDR 133Mhz VS 266Mhz
Athos
4
What is the advantage to using 133 x 2 rather than simply clocking at 266Mhz?
It would seem that on the data bus that you are going 266Mhz Even if you are only running the clock line at 133. Since there are 64 lines for SDRAM (72 w.ECC) it would seem that the single line at 133 has very minimal effect on power and RF issues.
Why add the complexity of a PLL (I assume that what is used) to divide the clock in half rather than just go 266?
Athos
4
I dont mean to disregard your answer but that is more of a consequence than a reason.
What is the cause of lower yeilds? Why is 133x2 easier to do?
Thanks, and I glad to be here.
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
Clock skew.
With the large number of parallel lines, it becomes harder to ensure that signals arrive on time, every time, the faster it is.
Evadman
Feb 18, 2001
30,990
Originally posted by: AndyHui
Clock skew.
Also the farther the distance, the harder it is to do. Memory is a little too far away from the north bridge currently.
