I did both and its quieter but its still definitely there. I guess it will never get all the way quiet...
i hear the occasional gurgle but i think thats the res just being a little empty. I don't have an aftermarket top. Will that solve everything? I was looking into that and it seems like it has potential to do that. The issue is everything is filled so there is no way for me to put on the top unless i drain everything. Or is there some tool I can use to cut off circulation briefly?
i might do the clamp thing. I don't mind getting air and the water can be managed. Have you done that effectively?
extremely painful loop. Its an matx box with a radiator on top that I mounted myself. Getting this apart and back together would take close to 6 hours. What top do you recommend for the future?
