- Jun 8, 2005
- 13,923
- 2
- 81
I DID IT! IT WORKS NOW! THANKS EVERYONE. HERE IS WHAT I DID FOR FUTURE REFERENCE
Problem: I had wired internet through my router but wireless internet was MIA, and I couldn't access the Gui of DD-WRT cause I didn't have a local Gateway.
SOLVED: First, I hard reset my router by the 30/30/30 Rule. Then, I went into the network connections folder, right clicking lan->properties->Internet Protocol(TCP/IP)-> properties. I checked "Use the following IP Address and filled this out.
IP Address:192.168.1.99
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
Use the following DNS server addresses: Preferred=192.168.1.1.
That got me back into the GUI by typing 192.168.1.1 into my web browser. However, just as I thought my problems were over, I was faced with another speed bump. My internet stopped working(through my router's lan port). I went to setup(in the GUI), and under Router IP, I filled this out.
Local IP Address: 192.168.1.1
Gateway:192.168.1.1
Local DNS:192.168.1.1
Then, I went into the MAC address clone tab under setup and copied the current PC address. Finally, I went back into network connections folder->Lan->properties->Internet Protocol(TCP/IP)-> properties and set everything back to automatic. That fixed everything!
I'm a layman when it comes to general computer stuff. Somehow, I got the bright idea to flash DD-WRT micro onto my WRT54GS. The flashing worked fine due to an excellent list of instructions, but its been a nightmare ever since.
The problem I'm having is complicated. I can't access the internet unless I'm plugged in through LAN. If I'm plugged in, and have access to the internet, I can't log into the WRT GUI through IE or Firefox or any other browser. Sometimes, I manage to randomly access the GUI through random restarts(Restarting everything, and pushing the reset button on my router for 20 seconds), but when I'm finally able to get into the GUI and change settings, I have no access to the internet. Wireless(internet) doesn't work even when the lan(internet) works.
Can anyone here help me troubleshoot? I've spent the past day googling every possible solution, and I've tried some simple ones, but some of what I've read is way over my head. If some kind soul shall help me, I will be eternally grateful!
P.S. I'm using a cable modem.
PPS Whenever I try to ping 192.168.1.1, I get no response. When I do Ipconfig, it gives a very strange number as my default gateway. 208.120.188.1(on my ethernet adaptor) ? It gives a blank under tunnel adaptor. Here is what it says when I ipconfig.
Windows IP Configuration
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : earthlink.net
Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethernet NIC
Physical Address. . . . . . . . . : 00-C0-A8-88-97-91
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 208.120.188.60
Subnet Mask . . . . . . . . . . . : 255.255.252.0
IP Address. . . . . . . . . . . . : ?
Default Gateway . . . . . . . . . : 208.120.188.1
DHCP Server . . . . . . . . . . . : 10.49.192.1
DNS Servers . . . . . . . . . . . : 207.69.188.185
207.69.188.186
207.69.188.187
Lease Obtained. . . . . . . . . . : Sunday, January 18, 2009 10:18:21 AM
Lease Expires . . . . . . . . . . : Sunday, January 18, 2009 10:18:21 PM
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter 6to4 Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : 6to4 Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : D0-78-BC-3C
Tunnel adapter Automatic Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Automatic Tunneling Pseudo-Interface
DNS Servers . . . . . . . . . . . : ?
