Why did AC win out over DC when DC is cleaner (less harmonic distortion) and uses less power?
I know that AC can be transmitted through longer thinner wire (so it seems cheaper), but why is that considered worth it when it uses so much more power and heat than DC? Isn't it just better to pay more for a thicker copper wire than to pay for conversion transformers and have the burden of using more power that's not even as clean if you don't use conversion? Also, if there is less harmonic distortion going to your components' power supply, then your components will last longer. I think DC power would be cheaper in the long run, since no need to have conversion modules, and no need to replace fried components, however rare that may be with AC.
DC was invented first, and it was expensive, but some of that had to do with the fact that Thomas Edison was granted a patent, so he kept the price up.
I'm not claiming to be an expert, but I think that DC power would cut down quite a bit on your electric bill in addition to be cleaner.
