I played in a basement for a while, tile over concrete foundation. We used a piece of carpet foam under our pads - it helped with impact and slipping, but it collected static. We had tried carpet first, but the pad would stay on the carpet while the carpet slid on the floor.Originally posted by: PingSpike
How are the soft pads anyway? I've read they can sometimes rip or get smooshed up. Should I throw down a piece of carpet?
Originally posted by: JLGatsby
An interactive dance game? You must be kidding.
Originally posted by: Queasy
I remember reading where someone did kind of a mod for their softpad. They duct taped it down to a piece of peg board then duct taped some cut squares of plastic on top of that.
Originally posted by: ShOcKwAvE827
uhh, your height? height of ceiling? this isn't baskeball. You jump 6 inches off the ground at most.
Originally posted by: Leper Messiah
you shouldn't be jumping uber high. I did fine at 6'3" with 7 ft celings.
