Damni..i need help with my tv tuner...
kicken14
Banned
May 22, 2000
725
Windows says its working fine..it came with some wavetop software stuff on the cd..whats that for?
its like the first tv tuner made by the company focus "Invideo tv tuner"
has antenna and fm, also the rca video in jacks...i put my cable into the both and no channels get detected!!!!
I have webtv for windows installed like it told me too...wtf is wrong with it...it should be working i need step by step on this
ALL THE DRIVERS ARE IN!
MrCraphead
2,977
lol@mosdef :)
well, first off, what kind of cable is it and did you plug it into the video in jacks or the coaxial jack?
MrCraphead
2,977
so you plugged your cable in the coaxial input for the TV, but the card doesn't pick up a signal? I'm not quite familiar with that brand of TV tuner, but most likely you'll have to mess with a few settings in the configuration menu or options.....have you tried e-mailing/calling tech support?
