Originally posted by: Grey
Didn't you just buy this motor? Did you race it or something?
Originally posted by: jeffrey
What's the problem... It sounds like you still have 7 perfectly good cylinders 😎
Originally posted by: Evadman
absolutely no compression? since you just installed the new heads I am going to hazard a guess that somethign happened with them instead of the motor. unless you punched a hole in a piston.
Sorry dude 🙁
Add 1 more cube to that 😉Originally posted by: Eli
Heh...
That's crazy. Be sure and find out exactly what the failure was so you can take measures to prevent it.
How did you find out? Was it running funny/lacking power?
302 huh? May as well just get a 350. 😛
Chevy engine in a Ford? Do something like that in Detroit and you'll get your ass kicked. 😛 Besides, the 351 Cleveland can wipe the floor with a 350.Originally posted by: Eli
Heh...
Heh...
ZV
Originally posted by: JC
Mebbe it just burned an exhaust valve. How about a leakdown test before you yank the engine?
JC
14.7:1 = most power.
JC
Yeah. Definately figure the exact cause of the problem before you start.
A/F ratio gauges rule. Why wouldn't you want one? Usually, it seems gearheads will take as much engine running information as they can get.
Actually, isn't 14.7:1 just the stoichiometric ratio for perfect combustion? Isn't max power slightly richer, and max fuel economy slightly leaner? Kinda hazy here, it's been awhile.....
JC
JC
Air/Fuel gauges rule?I think you meant a Exhaust Gas Temp gauge.![]()
an A/F is easier to install, which is why I recomended it. EGT's are the most useful with one sender in each port so you can watch each cyl independently.
