Damn, just got a Check Engine Light on my car
BoomerD
66,389
14,787
Check engine light errors are (generally) emission-related issues that the OBC has triggered on.
Take the car to Auto-Zone and they'll read the codes for free.
That does NOT always tell you exactly what's wrong however. Often, several things can cause the OBC to throw a certain code...but it's a good starting place.
And as SampSon sez...SOMETIMES they'll go off by themselves. (but not often)
BTW, the garage is over ----------------------------->
rudeguy
47,351
14
61
If it doesn't go off on its own, there are still other options. I have seen electrical tape and pictures of girlfriends used to fix a check engine light.
TruePaige
9,874
Don't worry, check engine lights never REALLY mean something is wrong with the engine. I've had them come on from drastic climate changes when I traveled before tripping my emissions sensor.
MotionMan
17,124
12
OMG!!!! Did you accidentally put Premium gas in your car?!?!?
/other overreacting car incident thread reference
MotionMan
episodic
11,088
1989 Dodge Truck here - mine has been on since 1996 . . . . never checked it out either. . .
WaTaGuMp
21,207
2,506
I had the light on for my truck and I couldn't pass smog with it on, how does that work where you are?
Jabbernyx
350
:laugh: :laugh: :laugh:
Seriously though, what vehicle make/model? On the old Cavvy it was an TPS, cheap fix. On the LS8, it was the fuel injectors followed by COPs = expensive.
episodic
11,088
They don't even have vehicle inspections where I'm at - thank god.
Fenixgoon
33,392
12,996
quite often it's just an O2 sensor or something else simple.. if it's blinking, THEN you're in trouble.
13,851
My dad gets the "check tire pressure" messages all the time. Damn southern built cars, they can't cope with real weather. :p The cold screws up the censors.
I'd get it checked to be safe, but not always something super bad.
WaTaGuMp
21,207
2,506
I hate you. :D
sandorski
70,802
6,357
I had a smartass comment all worked out, but realized that it was way too late to post it. :(
Anyway, here are 2 Suggestions
1) there's a sub-Forum for this
2) Check Engine
DeviousTrap
4,841
Has he checked the tires? Every 10 degree change of temperature is a loss of ~1 PSI.
91TTZ
14,374
The censors? Do you ever get an error message or is that censored, too?
