Dammit... Panasonic TH42pz700U problems... wont turn on
MikeMike
45,885
66
well, i have left the tv unplugged for a full day now after this started. The TV is about 1 year old and has been used a lot but this is weird. The TV will power on, show fuzz for .5 seconds, and then suddenly it will go black and the red power light just flashes... anyone have any ideas? I know i should call tech support and i am. but was wondering if anyone had any input on ideas for the problem...
it is 7 blinks inbetween pauses... grr... i do like their tech support though very quick to help.
CalvinHobbes
3,524
Seems to be a fairly common problem with these TVs. At least I found a lot of the same thing by Googling. If it's under warranty it will be fixed.
MikeMike
45,885
66
fuck. I believe i bought the tv in december of last year, if this thing broke not even a month out of warranty i will be PISSED if they dont honor it.
spidey07
65,469
Use the warranty protection from your credit card or see what you can do OVER THE PHONE with panasonic.
MikeMike
45,885
66
i will, but first i have to figure out exactly when i purchased it, i know the receipt is back at my house, and im in toledo. I could have my CC look up when i bought it, but that costs $5 which i might do but i have to first figure out what month i purchased it which is the main point of this entire process...
OneOfTheseDays
7,052
The SAME thing happened to me with this exact same TV. Turns out I was 2 months outside the warranty. Luckily I was able to get Mastercard to extend my warranty insurance, actually they ended up paying me the cost of the TV since the repairs were more than the cost of the TV itself.
MikeMike
45,885
66
It looks like i bought it around Dec 3rd or 4th of 07... that means i am a WEEK outside of warranty, o dear god will i raise hell.
Raincity
4,477
12
You should be OK with Panasonic according to the experiences posted over at AVS forums over this issue.
Christobevii3
995
Call panasonic, they'll usually fix it right out of warranty. But yeah the control boards failed and 7 lights points to power regulation failure. My pz77u did it after having the tv 2 months
MikeMike
45,885
66
the cost is $531... but panny is warrantying it... much less than i expected. I only had to pay $75 to get it inspected.
MikeMike
45,885
66
so i finally got my tv back last week, was out of service for 2 months, but it was all covered... thank god.
sdifox
99,364
17,548
got lucky I guess. My HC4900 PJ is on its way to Mitsubishi... Now I am down to the Westy 42" in the living room...
nakedfrog
61,775
17,494
Flyback transformer?
gar655
565
OK. Bought one, TH-42PX80U, on Monday the 16th. Brought it home, turned it on, started setup, TV shut off. No blinking LED, nothing. Let is set for 10 minutes. Tried again, same thing. Tried several more times. No luck. Back to Sears it went. Bummer is it was the last one they had and they aren't getting any more in. It was IMO as steal at $599. IF it had only worked.
We really don't want to spend anymore than that for a bedroom TV. You can hardly get a decent 32" for that. 40" is about the right size, 37" would work, 32" is kind of small.
Any recommendations for an inexpensive TV that would have PQ close to the Panny?
Thanks
Gene
