Damage to pci-e pins
p5200
35
I use Caig Deoxit on the switches and controls of my audio components etc. it might be worth a try also. :)
mfg_lv
18
The WD40 doesn't clean it, but maybe my toothbrush is not good enough.
However, I would be happy just if it stops the reaction. How often do I need to reapply it ?
inachu
2,387
THe proper tool to use is called Flux Off.
Any and all electronic professionals use it and swear by it.
mfg_lv
18
Can WD40 do the job if I spray a large amount of it ? Is it safe ? I hear it's dangerous to plastics.
Burpo
4,223
473
I told you to read up on it. Don't use a "large amount". It's a petroleum distillate that stops corrosion, and coats & lubricates. It is not harmful to plastics, but will impede/stop corrosion.
