spidey07, actually, hubs do exist. They've gone the way of the turntable - if you need one, you NEED one, and you will buy the high-end one. It's only the cheap hubs that are off the market.
And remember that good switches (usually the managed ones, and if you want it to work *right* the higher-end ones) do a decent job of filtering multicast, and can rate shape or storm protect broadcast.
eltigre15, unless your switch is stupid or operating way out of capacity, once it has learned where a station's MAC address is, it will only send things out the port that it thinks that station is down from. So it will not normally send a lot of excess traffic down the other switch ports. Cascading hubs off of a switch in the middle is exactly how things were done when switches first came out - this provided a way to keep your L1 collision domain under control as your network grew, and thusly helped performance a lot (collisions are *bad* for performance). As time went on the price premium for a switched port dropped dramatically, and now, today, you have to deliberately look for and pay more for a hub, because it's a specialty item.
An all-switched network is usually easier for a non-expert IT staff to build and maintain a working network out of. There are many headaches associated with a true CSMA/CD network that you just avoid. There are downsides to switches, but most home and business environments won't be hurt by the downsides, and benefit from the upsides - so for most folks switches are the better choice.
