Dumb question, I'm sure, but that probably means a simple answer....
Can 80mm fans be daisy-chained together, then plugged into a single molex connector? My Antec case came with two standard 80mm fans in the back, each with male & female 4-pin power connectors. Can I plug the two fan connectors together, then plug the remaining end into a single 4-pin molex connector or do I need to use a molex connector for each fan?
I plan on running 4 or 5 fans and I might run out of PSU connections if I have to connect each fan to its own molex connector.
Thanks in advance for the feedback.
