Daemon Tools help!
GoodToGo
3,516
I am using daemon tools to backup my DVD's using the following method.However Daemon tools is giving me problems and after burning the first DVD successfully, it REFUSES to unmount the previous image. I have tried everything from reinstalling to messing around with the settings but nothing seems to be working. Any help iwll be deeply appreciated.
GoodToGo
3,516
Anyone??
yodayoda
2,958
personally, i don't use daemon tools for ICing. when you use DVD Decrypt or SmartRipper, rip them as files (VOBs and IFOs and such) instead of a disc image (ISO). the principle reason to rip to ISO was to conserve the Audio_TS directory. but since the InstantCopy patch (linked by the page you referenced in fact), InstantCopy automatically makes an Audio_TS directory in their encodings. so there is no reason to rip to ISO and use Daemon tools. simply rip as files and go straight to IC. i use Daemon tools afterwards before i burn just to make sure the DVD looks good. hope that helps.
