D865PERL Audio
spedmen
Hello, before i get to the actual problem a little background info:
I used the D865PERL for multiple year without any major problem, the case that i had it in had a Front Audio port which i used from time to time, recently i upgraded and changed out the D865PERL for a diffrent Mobo, the D865PERL was used to make a second computer in a case without front audio port, so for some unknown reason the mobo thinks that something is plugged into the front port even though it is not even physiclly conected so it treats the "something" as headphones so no audio works, but when I used the front port cables and plugged them into the mobo the audio worked perfectly, front port and back port, what I am asking is if there is a possible way to disable it somehow or is the only solution is to buy a case with Front port audio?
