D2 not running in XP
potato28
8,964
Search is broken...still... and I made a topic about this a while back. So I ask again, how do you get Diablo 2 LOD to run in XP? I have DEP off for it, but it crashes to desktop.
shortylickens
80,287
17,081
I dont even know what DEP is, but I never had a problem with Diablo 2 in XP.
Does it give a tech readout when you crash?
secretanchitman
9,352
23
i just installed diablo 2 (mutiplayer or full) install...then put in my lod cd and installed it, then updated to 1.11...no problems in xp.
Judgement
3,815
Maybe try going to the executable properties and setting it to run in a compatibility mode for a different version of windows?
Dumac
9,391
Do you mean Vista? IIRC, there is an incompatibility problem with D2 and Vista, as well as a fix for it. However, D2 worked fine on my XP comp without any extra assistance.
potato28
8,964
Worked... I used to run it through the data execution process in XP. Worked fairly well, but runs better in compatibility mode.
