I missplaced my firmware disk that came with my router. Can I use the "upgraded" firmware on the D-link site? Or does an "upgrade" require the original to be installed first?
I plan on using the 704 router with Sygate firewall and XPpro's PPOE. Is this the best set-up? My DSL will be Verizon. I've been doing some research on the big WWW, yet I'm only finding fragments on how to install and set-up each individual component. I need to have an idea of the order.
Yes, I know the NIC card is first and then I contact Verizon who will also supply the DSL modem. After Verizon sends me the DSL modem, I hook up all my hardware. When do I then set-up the XP PPOE and install Sygate?
Thanks
Thanks
