D-Link 7 port USB 2.0 Powered Hub: $7.00, Power Supply: $4.50, Cable:2.50
Status
Not open for further replies.
Harvey
Administrator<br>Elite Member
If you want need more ports or if your older case doesn't have front mounted USB ports this is a hell of a deal.
D-Link #DUB-H7. 7 port USB-2.0 Powered Hub
$7.00
CAT# USB-71U
You can connect it to a standard power connector in your machine or use a wall wart. Be sure it has the right connector and polarity and delivers 5 volts at 3.0 amps minimum (D-Link spec). The USB spec is 500 mA (0.5 amps) per port so 3.5 amps is better. They have this one:
5VDC 3.7A SWITCHING POWER SUPPLY
$4.75
CAT# PS-537
It connects with this kind of cable:
6' USB A-B CABLE, 2.0 HIGH-SPEED
$2.50
CAT# CB-347
If you live in or near Van Nuys, Ca., All Electronics (Oxnard west of Kester in Van Nuys) has a B&M store:
All Electronics Corporation
14928 Oxnard Street
Van Nuys, CA 91411
(818) 997-1806
Their catalog items can be ordered online. Of course, you'll pay shipping.
Order online by catalog ID #, or
Toll-free Order and Customer Service: 888-826-5432
While you're on their site, check 'em out. They have a wide variety of wall warts, USB and other cables and a lot of other stuff at great prices because they buy a lot of closeout items and large lots of overproduction. For example, these hubs are listed as used. The two I bought look new to me. 😎
Keep in mind that there is a minimum $7 S&H cost for people who can't pick it up locally. So it would be at least $21.25 to get a "used" version of the full retail version (that would be with the AC adapter, USB cable, and S&H.)
You can get this, new, for $23.99 shipped at Buy.com.
I think the real deal here is for people that already have the cable and/or an AC adapter, or can pick it up locally to avoid the S&H. $7 for just the hub is pretty nice. But I'd probably pay an extra couple bucks to get the full retail package with OEM accessories if I needed it all.
You're right that this deal is best for those who can take advantage of local pickup. I already had the cable so I was out the door for $11.75 + tax. $2.50 more for the cable wouldn't have killed the deal.
As noted, the two I bought look new with no scratches or other visible damage. 🙂
Status
