CyberPower Intelligent LCD Series GreenPower UPS CP1350AVRLCD 1350 VA 810 Watts 4 x 5-15R Battery/Surge Protected UPS
Pardus
CyberPower Intelligent LCD Series GreenPower UPS CP1350AVRLCD 1350 VA 810 Watts 4 x 5-15R Battery/Surge Protected 4 x 5-15R Surge Protected Outlets UPS - Retail
$154.99 - coupon code EMCAKBKCA = $131.99 shipped, Expires 9/25/08
Model
Brand CyberPower
Series Intelligent LCD Series GreenPower UPS
Model CP1350AVRLCD
Input
Input Voltage Range 90 - 140 Volts AC
Input Frequency 57 to 63Hz
Output
VA Rating 1350 VA
Watts 810 Watts
Output Voltage 120Vac +/- 5%
Outlets 4 x 5-15R Battery/Surge Protected
Battery
Battery Run Time Entry-level PC with 19" LCD (150W) - 30 min.
Midrange PC with 19" LCD (300W) - 14 min.
Performance PC with 19" LCD (500W) - 7 min.
Battery Recharge Time 8 Hours
Spec
Interface Port 1 x Serial DB9; 1 x USB 4-pin
Management Software PowerPanel Power Management
Approvals UL 1778, cUL, FCC DOC Class B
Surge Protection
Data Line Protection 1 x RJ11/45 Combo (One-in/One-out)
1 x RG-6 Coax/Cable
Surge Energy Rating 1500 joules
Physical Spec
Weight 23 lbs.
Dimensions 4" x 9.75" x 13.25"
Features
Features GreenPower UPS
Intelligent LCD Diagnostic Display: The innovative front panel LCD can be used to display detailed information on the UPS status and current power conditions. The LCD displays 11 different diagnostics: Input voltage level, Output voltage level, Automatic voltage regulator, Runtime estimate, Load level, Power frequency, On battery, Overload, Fault, Battery capacity, and Silent mode.
Automatic Voltage Regulation (AVR) - Incoming AC power is electronically regulated for dips and spikes AVR takes this irregular AC power and converts it into a consistent Sinewave so sensitive electronic equipment can achieve its optimal performance.
EMI/RFI - Provides shielding against electromagnetic interference & radio frequency signals. Most commonly, this is used to prevent line noise or ?humming? that occurs over telephone lines or stereo electronics.
Transformer-spaced Outlets - Widely spaced outlets allow you to conveniently add large transformer-based plugs without compromising the utility of other outlets.
USB Connectivity - HID compliant USB port enables full integration with built-in power management and auto shutdown features of Windows, Linux and Mac OS X.
PowerPanel PE ? Smart Management Software ? In event of a power outage, PowerPanel PE will not only save your open files and will also ?Hibernate? your PC to increase the run-time on the UPS unit. PowerPanel is quickly and easily installed on any Windows-based PC and is designed to utilize minimal system resources. Diagnostic screens give immediate visuals of the UPS?s status, and also include the following features: Silent operation mode, configurable system notifications, automatic self tests, adjustable high/low voltage warnings, event/data logging, and scheduled shutdowns.
LED Indicators - LED status lights indicate Power-On and wiring faults.
Audible Alarms - Audible tones identify when the unit is running off battery power, unit overloads and low battery.
Packaging
Package Contents CP1350AVRLCD UPS
Power Management Software
Coaxial Cable
RJ11 Cable
USB Cable
User Manual
I like auto-shutdown for Linux!
Do they make these with Li-ion or NiCd batteries? How long is the battery good for (10 outages per year, computer run 24/7)?
I don't know what kind of batteries they use, but ours has worked great. We've had two power outages this yr, I have it set to turn our server off when it estimates 8 minutes of run time left.
