I went to HomeDepot to pick up the Dremel Toolkit ($59.99). I miraculously found a salesman there, and I asked him about the Dremel. Basically, he said that is was more for "arts and crafts", and that if wanted to cut sheet metal easily I should get a RotoZip spiral saw ($99.99).
Since I haven't used either of the two, any suggestions? Practically, most people doing mods are using Dremels, so I'm not sure. But, alot of those people have reported going through plenty of cutting "discs." (Yes, I don't know much about tools/hardware). If that's not the case with the RotoZip, then I'd be inclined to go for it. Unless, of course, there other advantages to having the Dremel.
Any thoughts on which of the two may be the better way to go: rotary tool or spiral saw.
Some Info on the RotoZip:
Rebel? Spiral Saw? and Zip Mate? Attachment Combo Kit
Model ZMREBEL
Cut, grind, sand or polish virtually any material
RotoZip® Rebel? Spiral Saw? cuts almost any building material up to 1" thick
5.0 AMP power
Features 2 speeds: 24,000 and 30,000 RPM
Three position bump off switch
Features an air diverter to clear away debris from your work surface
Easy to remove handle with additional bit and collet storage
10' reinforced premium rubber cord
Zip Mate? attaches to Rebel? saw in less than a minute
Zip Mate? adds cutting, grinding, sanding and polishing capabilities
Three grits of See-Thru? grinding, sanding and polishing discs included
One metal and one masonry cutting wheel included
Combo Kit includes Rebel? Saw, Zip? Bit accessory pack and Zip Mate? Starter Kit
Model ZMREBEL
5.0 AMP power
