2 rollers pipe cutters do not tract well, that tend to spirals. The trick is to wound the pipe one way 1 complete turn then wound it back 1 complete turn to establish cutting track. 3-4 times wound it back & forth as you tighten the knob 1/4 to 1/2 turn each complete turn, and it can be wound in 1 direction to cut once the track is established.
4 rollers pipe cutters with large diameter cutting wheel is it the way to go.
Do not over tighten (rush) the cutter as you cut because it can ovalize the pipe, and there are deburring tool or reamers that is use to clean out the burrs in the pipe.
Hack saw work well if you have a steady hand and something rigid to brace against as you cut.
Or use a steel cutting saw blade to get a mirror finish cut and it is absolutely square.
Freud diablo metal demon
