- Apr 28, 2004
- 1,187
- 0
- 76
I want to Cut out the stock fan grills on my SilverStone LC14 Case that uses the smaller 60 mm fans and replace them with wire grills Other then make the case look nicer does it have any other benifit? Will it increase fan airflow and reduce noise? I have a holesaw thats alittle bit smaller than a 60mm fan and I will probably use that
http://images.dr3vil.com/files2/default/SilverStone LC14Back.jpg
