Cutting into a Lian-Li
DukeChestnut
349
I have the pc-65 and am thinkin bout adding a 120mm fan up top. anyone ever drill into an aluminum case? is it softer or harder than a reg metal case? and u think i'm makin a mistake with messin with an aluminum case? i woodn't want to deface a lian-li.
Woodchuck2000
1,632
Apparently it's easier than a steel case.
That said, I wouldnt have the heart to touch my PC-60 with a dremel...
Mitzi
3,775
Exactly what I was thinking - I wouldn't deface my PC60USB :)
But yes, it should be easier to cut than steel.
Jeniva
23
Thats a nice case to be drilling on...IMHO I would use a HOLE SAW before a dremel on that case...it will be easier and faster (especially if you dont have lots of experience with a dremel)...Good luck with the mod, and give us a link to some pics when you finish)
(my web server is currently down for maintenance..if you would like to see my mod pics please follow this Link)
