- Apr 12, 2001
- 4,508
- 0
- 76
OK, you've all seen cheap cases that have the grills pre-cut into the side of the case for "airflow"... Anyway, I am going to be cutting a 92mm hole into the side of my case with a hole saw. This grill poses a problem though because half the hole will be directly through the grill. I've done it before and just hacked it up. The hole saw always catches on the grill holes and it makes it hard. This time I don't want to mess up the case, since I do like it.
My only idea is to trim the grill with a dremel before using the hole saw. That way the hole saw won't catch on the grill. Not the ideal solution, since it will take a lot longer, but it's all I've come up with so far.
I'm using this case here. You can see the grill on the left side.
Anyone have any suggestions on how to get through this problem? (don't tell me to get a new case...)
