cutting 120mm hole in case
leegroves86
400
I want to cut a new 120mm hole in the bottom or top of my old case. I don't own a dremel but I own a drill. How hard is it to locate a 120mm hole cutter that fits on like a drill bit? 120mm is like 4.7inches??? seems like it might be an odd size. Can i find it at wal-mart or do i have to buy it online?
MadScientist
2,186
63
120 mm = 4.724". A 4 3/4" (4.75") holesaw will work. Some use a Dremel, others holesaws, I use a jigsaw and clean the hole up with a Dremel. I use a CD-R as a template. It's 119 mm in diameter.
0roo0roo
64,795
84
120mm bit sounds like a handfull to work with heh. u got an axe?;) whackity whack whack + hot glue ftw!
BonzaiDuck
16,822
2,143
I'm not sure buying the hole-cutter (drill-type) for a one-time use is particularly cost-effective.
Look for a sale at Radio Shack on a "nibbler" tool -- they usually sell for less than 10 bucks but I've got them for half price, and they're at least good for several projects until they weaken and die (usually from application to metal that is too thick.)
I've found that a dremel cutting wheel works very well -- with patience -- on 120mm fan holes. Maybe you could borrow a dremel and cutting wheel.
Also -- suggest you look at some projects at Overclockers.com and other web-sites devoted to case-mods. One mod I've seen adds some cabinet-work to the case, by designing an oak (or other) wood box with a rabbited edge at the top to snugly fit the bottom of a computer case. Air is drawn through filtered holes in the bottom and rear, by a fan flush with a fan hole in the metal case-bottom. With or without foam padding inside the wood box, it is a virtually noiseless fan deployment, and not only can you add more than one fan-hole and intake fan, but the filters and intake ports can be large enough to really increase airflow while keeping the dust out . . . . and the noise in . . . .
Ika
14,264
if you want to be tedious you could draw the outline of the hole you need, then drill every 1cm or so around the edge, then either punch it out or drill more holes.
GalvanizedYankee
6,986
Originally posted by: pacho108
which one is effective to cut a hole on the side plastic window?
The way I'd do it. Drill the fan mounting holes. Sam-itch the plexi between to 1/4" pieces of plywood held together with long 8-32 bolts, mark an X between the bolts and use a cheap hole saw from Harbor Freight in a slow speed 3/8" drill.
Prior to the sam-itch cover both sides of the plexi, in the area being worked, with masking tape to pre-vent scratching. Also direct a fan at the hole saw to keep it kewl.
After the work, chamfer all the dead 90s to pre-vent cracks from starting. Do all mounting holes and the main hole.
The above will ree-sult in a pleasent a-peering holely moley.
...Galvanized
Greenman
22,397
6,522
A good quality fine tooth hole saw is the way to go. Yes, they cost 30 to 40 bux, but they work very well and will cut a lot of holes. A nibbler will also work very well, but takes a lot more time. If you don't want to do it yourself, find a machine shop and have them do it with a punch press. Takes 3 seconds and you end up with a perfect hole.
pkme2
3,896
I used a RotoZip to cut out my 120mm hole on top of my Lian-Li.
You can used a protracter to mark and cut with a drill cutter/grinder to do the job too.
One can used almost any tool, but a clean, neat hole is always firstplace, right?
Your choice.....
