customize right column in xp start menu
ShadowBlade
is there a way to do it?
i.e. could i remove the program access control or w/e and add my videos?
and also is there a way to add seperators to the left column and under all programs
You can also customize it much more by changing the text on the start button, and modifying the interface.....pretty much anything you would like to change, you will need a program called Resource Hacker, just do a little google search and you will find it.
The only machine running win XP pro at my place has everything in there pretty much altered example :
1- Instead of the Win logo on the start button I have an IBM logo.
2- Instead of Windows XP professional on the side menu it now says Windows XP: Pro Sucktional ...etc
Give Resource hacker a shot you will like it.
I've used this once before, I remember there was some big long process of getting it to work with the modified files involving booting into safe mode and replacing the file. But I dont remember exactly what to do.
