Toastedlightly
I am making a custom case out of a wood base and plexi sides. The motherboard will be secured to the base using studs, basically the same ones used to put it in a normal computer. My question is, do I have to worry about any grounding issues? Just wondering.
-Toastedlightly
-Toastedlightly
