CUSL2 CPU Monitor. Help!!!
venomrat
Installed ASUS Probe software onto my new system.
The CPU is shown to be running around 40 degs C.
When I use CPU intense programs ie Quake III. The temperature peaks to 78 degs C. It begin cooling
soon after the porgram stops. Don't think the CPU is over heating.
What am i doing wrong? Is there some connenction i missed out? There is nothing in the manual that says I must make some sort of connection for the software to work.
Advice appreciated.
jzodda
824
You might want to redo your heatsink setup cause the ASUS probe in windows reports a lower temp than it should. So your 40C might really be higher still.
You have thermal compound on the cpu?
