Currently using MusicBrainz. Anthing else?
ThatWasFat
93
I really like MusicBrainz, but I'm always open to better alternatives. Anything else I can use? Or is MusicBrainz the best.
Confused
14,166
I had to spend about 2 weeks of 3 hours per evening sorting out my 2500 songs after MusicBrainz screwed all the filenames/paths/tags up.
Luckily, it put most of the stuff into sub-directories of the directories they should have been in, but I still had to check about half of the files to try to figure out which was the right ones.
Confused
