Is there anything you can do in DPP that you can't do in Lightroom or Photoshop or <insert program>?
Until the thread of raw support is gone, I will unlikely bother with DNG (unless my camera natively supported it). I'm all for a universal raw format, but that will unlikely ever happen.
HOWEVER, adobe has claimed they might be able to increase workflow performance if you work in DNG. I'm a bit skeptical, but if it proves to be a significant boost, I'd consider it. source: http://news.cnet.com/8301-30685_3-57371809-264/adobe-offering-new-reasons-to-get-dng-religion/
Has anyone else picked up support of DNG?
Has anyone done a benchmark to see if LR3 actually improves with use of a DNG?
Until the first is true, DNG is proprietary in my mind.
3. Adobe - They must be getting something out of this....
Because the final RAW output isn't necessarily in the same order. Maybe canon writes out 10,000 arrays containing the time array elements and maybe nikon writes out at each time point an array of 10,000 exposure info. It's the same data, but in two different formats. DNG would convert RAW to the same arrangement of data, so you wouldn't need special software to parse out the specific output of each sensor. You also net some additional compression, which helps if you have a couple thousand 20-30MB files.
